Failed to open stream: No such file or directory in
I'm returning to this web site. Other files searchable in the database still work.
A search produces results of database info, including a link to the music file.
Previous files all work fine. the newly added song "Mama," does not and produces a warning. I've tried re-uploading the web assist folder. The problem persists. (Coincidentally, I had a problem logging in with previous registrations —is that a clue?)
Receiving this warning:
Warning: require_once(../webassist/security_assist/helper_php.php): failed to open stream: No such file or directory in /home/affinity/public_html/cat/weathers/Mama.php on line 1
Fatal error: require_once(): Failed opening required '../webassist/security_assist/helper_php.php' (include_path='.:/usr/lib/php:/usr/local/lib/php') in /home/affinity/public_html/cat/weathers/Mama.php on line 1
Please give guidance.
Thanks!
