Query String issue with DA and Framework
Thread began 8/17/2015 8:45 am by codamedia | Last modified 8/17/2015 5:00 pm by Ray Borduin | 1084 views | 4 replies |
codamedia
Building an admin area with includes and database is causing some grief. Most I can overcome, but one issue is plaguing me.
Because I use Framework, my URL becomes ....
index.php?page=cyiLocUpdate (NOTE: page= is now the first part of the query)
All links and redirects with DataAssist pages set the query ID to use ? but since it isn't the first, it should be using &.
EG: index.php?page=cyiLocUpdate?id_loc=1
should be: index.php?page=cyiLocUpdate&id_loc=1
Where do I make that change on a DataAssist page? I thought I found it, but anything I try just results in PHP errors.
Can you send a sample page. I'll take a look.
codamedia
hi Ray, I'm attaching three files for you to view.
A results page, an insert and an update.
I see the bad code right on the page... for instance on the insert page on line 28 it has:
$WA_redirectURL = "../index.php?page=cyiLocDetail?id_loc=[Insert_ID]";
where it should be:
$WA_redirectURL = "../index.php?page=cyiLocDetail&id_loc=[Insert_ID]";
I'd just go through and manually make the corrections to the redirect page values at this point.
codamedia
Yes - that is obvious isn't it :)
I hadn't had a problem converting these in the past... not sure how I missed this.
Thanks Ray...
