How to create recordset in mac DW CC using DBridge 1.22
Thread began 7/28/2015 11:13 am by tmcbinc99963 | Last modified 7/30/2015 11:31 pm by Ray Borduin | 549 views | 4 replies |
tmcbinc99963
Connecting to database on localhost MAMP Apache w DW CC using DBridge 1.22
How do I create a database connection in Data Bridge? The only way I've found is indirectly through one of the Wizards, but can't get that to work.
My Database panel used to work but now doesn't. All the procedures are checked, but + doesn't work. Do I need this panel anymore?
The Wizard seems to find my database but not the tables. When I attempt to create another connection using the Wizard (using the same successful connections previously used without the Wizard), I get 'Unidentified Error has occurred'.
Using MAMP PHP 5.6 and MySQL 5.1 on localhost Apache server
You have to install the "Deprecated Server Behaviors" extension available from the adobe plugins.
tmcbinc99963
I had the Adobe Extension installed but the Wizards wouldn't open. They would flash on the screen and immediately close. I then removed the Adobe Extension, which allowed the Wizards to open, but can't get a connection.
I thought Data Bridge eliminated the need for the deprecated server behaviors.
Using the Wizards to create a connection doesn't work, even though I'm using the same settings as with the Server Behaviors.
You need to have the Deprecated Server behaviors extension installed or it won't work. Please re-install that extension and try again.
If you still have issues we will help you fix them, but the current issue is that the necessary extension is not installed.
tmcbinc99963
Thanks. I'm sure I'll have more questions, but good for now.
