I'm having an issue with a blank page after i hot submit on the checkout page
Thread began 7/22/2015 2:46 pm by Solis Web Design And Hosting | Last modified 7/23/2015 5:15 pm by Ray Borduin | 341 views | 5 replies |
I'm having an issue with a blank page after i hit submit on the checkout page
Having issue with a blank page after the checkout confirmation....view image..
Can I get a copy of: croxcart_PHP.php
I'll take a look at the line of code causing the error and suggest how to fix it.
Here is a copy of the file you equested
croxcart_PHP.php
It looks like you have a shipping and handling per item rule set to get a value directly from a Recordset. That won't work. You will need to save a session variable with the result from the recordset and use that in the shipping rule instead.
thank you i will try that and post the results...
The reason i added this is because my client wanted controls over a certain rule
It will work fine once you save it in the session.
