Recordset is not displaying on page, and it's also not showing up in Bindings panel
I am attaching my results page. I suspect the search area on the page isn't working as well. Thank you...
It isn't showing up because of the extra blank line on line 98. There should only be one blank line between the recordset and the totalrows code. Dreamweaver can be picky about things like that.
It's sort of working, except it keeps telling me I don't have any records in the recordset, even though I know I do. I tested the query on the server through PHP MyAdmin and I should see 8 results. Do you want FTP access???
Thank you.
Let's start with a URL so I can view the page.
The FTP information you provided doesn't seem to work for me. Please confirm that there are no typos.
Sorry, something got cut off. see PM for FTP PW.
You had your recordset parameter set to:
$_Session['SecurityAssist_UserID']
and it needs to be:
$_SESSION['SecurityAssist_UserID']
Because SESSION needs to be capitalized??? Also the search function is not working on the results page.
