Var char fields, radio buttons
Thread began 7/18/2015 4:33 pm by Patrice | Last modified 7/20/2015 5:34 pm by Ray Borduin | 473 views | 4 replies |
Patrice
So this is a messy question because I'm using WA DataAssist to edit CoffeeCup generated form results. It has always worked in the past, but I hadn't ever fiddled with radio buttons with CC forms.
CC use of radio buttons generates a var char field instead of 'set' or 'enum'. The information gets into the database ok.
When I tried to create an admin area for client using that database table, I get errors messages such as
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'when FROM
I have tried to change the varchar to a set, using the input values but database wouldn't allow it. I tried using just text fields in WA to create the results form, I tried using radio buttons options, etc.
I just can't get the DA to play nicely with the table generated by CC.
I tried asking CC, but was told it was a database question, so no help yet. I then asked in the forum.
So if the submitted form results in a varchar field, what would the secret handshake be for options in DA when creating the admin area? I've tried everything that seemed obvious to me, but I'm not there yet.
Patrice
Ray, please see PM
Patrice
To Ray
If you want I can do a screen sharing session to see if I can find a solution for you. I've never used CoffeeCup, so I think I'd need to work with you directly. Feel free to email me directly and I'll do screen sharing to try to debug what is going on.
Patrice
Thanks Ray. I did a work around for this particular instance. Instead of radio groups, checklists, I did singular check boxes which while clumsy worked.
