hyperlinks inside a MySQLi Repeat Region: only the last one works
Hi Ray and Jason:
I ran into a curious problem today. On a page where I have a MySQLi recordset that loops over data in our Stories table, I've inserted the MySQLi Repeat Region to display 8 stories from our #Iam1in5 campaign. In each repeat region, I've added a paragraph with a call to allow visitors to give in support of the campaign. All of the text appears correctly. The hyperlink color is correct for the text, but the first seven iterations of the hyperlink in the loop do not work. Only the 8th (last) one does!
You can view this page at: http://www.abilityconnectiontexas.org/iam1in5.php
I was wondering if you have seen this issue before, and what can be done to fix it. I have attached a text file with the recordset and repeat region code.
Thanks for your advice!
enthusiastically,
Mark
