missing install jpg
Thread began 6/18/2015 3:21 pm by darryl394578 | Last modified 6/19/2015 4:40 pm by davehampton | 504 views | 6 replies |
darryl394578
missing install jpg
I believe I am having the same issue with the php within the "installed.jpg" file. I've read the posts, but don't know how to do what has been presented. Can you help?
I get the following error after having installed powerstore, I've tried a couple times and it still gives me this error:
Warning: require_once(../../webassist/themes/Default/images/installed.jpg) [function.require-once]: failed to open stream: No such file or directory in /hermes/waloraweb017/b1390/moo.darryl9906/opportunities/webassist/themes/theme_open.php on line 63
Fatal error: require_once() [function.require]: Failed opening required '../../webassist/themes/Default/images/installed.jpg' (include_path='.:/usr/local/lib/php-5.2.17/lib/php') in /hermes/waloraweb017/b1390/moo.darryl9906/opportunities/webassist/themes/theme_open.php on line 63
If you can give me FTP access to the server in the private area, I'll fix this problem for you.
darryl394578
See private message
I don't know what URL to use to test, but I updated the files. If you still have issues, post the url displaying the error so I can debug it.
darryl394578
Error, still:
Warning: require(index.dwt.php) [function.require]: failed to open stream: No such file or directory in /hermes/waloraweb017/b1390/moo.darryl9906/opportunities/webassist/themes/theme_open.php on line 88
Fatal error: require() [function.require]: Failed opening required 'index.dwt.php' (include_path='.:/usr/local/lib/php-5.2.17/lib/php') in /hermes/waloraweb017/b1390/moo.darryl9906/opportunities/webassist/themes/theme_open.php on line 88
to test/view, go to: diagtest-cow.com/opportunities/
Your store is up and running.
darryl394578
Thank you so much.
