pagination update
Thread began 6/16/2015 8:22 am by Jamie | Last modified 6/19/2015 10:49 am by Ray Borduin | 3619 views | 18 replies |
Jamie
pagination update
Hi Ray
I have a results page which spans a number of pages and I use the pagination to navigate through it.
If, for example, I was on page 4, select an item from that page to update and then click update, what do I need to put in the update record 'go to' to automatically go back to page 4 (rather than the starting page)?
The url looks like practicebrands_results.php?pageNum_WADAbrands=3&totalRows_WADAbrands=102
Cheers
Jamie
Save the value of $_GET['pageNum_WADAbrands'] on the results page as a session variable on top of the page. Then you can pass it back in the url after updating to return to that page.
Jamie
OK
I think I have set the session on the results page
@session_start();
if (!isset($_SESSION["BrandsPaginationReturn"])) {
$_SESSION["BrandsPaginationReturn"] = "".$_GET['pageNum_WADAbrands'] ."";
Is that right?
Then on the update page, I am struggling to construct the redirectURL in the server behaviour update record
At the moment I have
$WA_redirectURL = "practicebrands_results.php".$_SESSION['BrandsPaginationReturn']  ."";
What am I doing wrong?
Your trigger for setting the session variable is wrong... it should be:
if (isset($_GET['pageNum_WADAbrands'])) {
Then make sure on your update page you are starting the session on the top:
@session_start();
Jamie
cheers Ray...
the session_start on the update page, is that it or do I need to reference anything? If thats it, the URL I have is still not redirecting back to the right page...just goes to the first page of the results.
The redirect needs to add the parameter name too:
$WA_redirectURL = "practicebrands_results.php?pageNum_WADAbrands=".$_SESSION['BrandsPaginationReturn'] ."";
did you update the trigger on the result page as I recommended?
Jamie
Yes, changed it to
@session_start();
have changed the redirect url as you have suggested
Still returning to the first page
What is the URL when it returns you to the first page?
What happens if you write the url to the update page like:
<?php echo("practicebrands_results.php?pageNum_WADAbrands=".$_SESSION['BrandsPaginationReturn'] .""); ?>
Does it look correct?
Jamie
the return url is just practicebrands_results.php
As to the second q, it lacks the ID this is the output onpage: practicebrands_results.php?pageNum_WADAbrands=
Do you have a URL where I can view it? It sounds like the session variable isn't getting set properly.
