checkout success error
error when click download button on checkout_success page:
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near '==1' at line 1
The download button on this page should just be a link that takes you to the download center for that user.
You can do that by adding the download center page name to the action of the form on the success page like:
action="file_download.php" (of course use the name of your download page)
Ray
Thnx, that worked just fine and I went to download_center.php and downloaded the PDF but now when I click Checkout from cart I go directly to Paypal not Login.
That is probably because you have already logged in. It will only ask you to log in the first time in your browser session.
Makes sense, I'll check over the weekend. Have a great one! Thanks again.
