Shipping based on area and quantity
Thread began 6/08/2015 10:53 am by ZP | Last modified 6/08/2015 1:42 pm by Ray Borduin | 1321 views | 5 replies |
ZP
Hello,
I am trying to do a calculation in Cart 6.1 in relation to a shipping.
I have a attached a freight pricing sheet based on the following.
1. The freight is charge per ever 5 boxes and or items.
Example
Freight per one 1-5 items is the same
Example
up to 10 boxes (items) = $6.83
up to 10 boxes (items) = $13.65
up to 20 boxes (items) = $20.48
I have a freight in the database that reflect the charge as user_states which has all the charges in it.
as "charge1, charge2, charge3 charge4" etc.
How can I get the cart to reflect this freight price?
If you wanted to do it from the database, then you would add a recordset to the cart page and have it filter based on the value of $eCart1->TotalColumn("Quantity"). Once the recordset returns the correct charge, then you can store that as a session variable and use the Shipping tab in the eCart object to add a shipping charge equal to the value stored as that session variable.
Perhaps an easier way to do it is to not use the database and add the rows as individual shipping rules. You would add one shipping rule per price and set them "based on the number of items in the cart" with the flat rate charge based on your spreadsheet.
ZP
There is a session variable set upon login "ship_state" which has a dollar value.
If I could help with adding some code to this line please:
//eCart Rule
function WAEC_eCart1_BigChill() {
$totalShipping = 0;
if (true && ((sizeof($this->Items) > 0))) {
$totalShipping += (floatval($this->GetInfo("5", "Quantity")) + 0.00);//Result
return WA_eCart_FormatNumber($totalShipping, $this->ForceDecimalsC, $this->DecimalPlacesC);
//eCart Rule
//end node
Don't edit the code directly. Use the eCart object to edit the code. If you start hand editing, then you won't be able to use our interfaces to make further edits in the future.
That code is controlled by the Shipping tab in the eCart object. Edit it from that interface.
ZP
Yes I realise that I must use the interface.
I was wondering if you could please assist with the correct formula?
Please view the attachment.
Just set it to charge "if session variable exists"
and set the charge amount the the session variable value like: $_SESSION['var_name']
