Accessing Data from an upload form in another page (Data Bridge)
Thread began 6/05/2015 3:11 am by Mohammed Aji Wajiro | Last modified 6/08/2015 12:44 pm by Ray Borduin | 1476 views | 3 replies |
Mohammed Aji Wajiro
I have two forms on separate pages. One contains a file field with upload server behaviour and has an action of loading the second page if the upload is successful. I want the data on the first page to be use on the second page. Although i can see that a session variable has been created by the upload page. But it shows an index error message whenever i used it.
You may need to manually start the session on the top of the second page before you can refer to it:
@session_start();
Mohammed Aji Wajiro
I did as instructed by yet does not work. Whenever i used that session variable i get this message on the page: 'undefined index: uploadpic_picture in c:\www\wamp\portal\register.php
It must not be stored in the Session. You can use the "set session value" server behavior on the upload page to save a session variable explicitly so that it will be available later in the process.
