Progress Bar Not Stopping Form Submission
Thread began 6/01/2015 2:25 pm by wdtp.com | Last modified 6/03/2015 11:35 am by Ray Borduin | 2331 views | 5 replies |
wdtp.com
Progress Bar Interfering with Spry Validation
I have a Progress Bar on the below page with Spry Validation. The Progress Bar is interfering with the Spry Validation by allow the form to submit even though one or more fields fails validation. Everything works without the Progress Bar but with it the validation fails to stop the form submission.
http://2015.newtownwilliamsburg.com/admin/coupons/coupon_edit_test.php
Any ideas?
Can I get FTP access to debug? My guess is that multiple versions of jquery on the page are causing the problem or perhaps a javascript error in one of the other files. I see a few errors onload of the page... I'd have to debug to be sure.
wdtp.com
FTP details in private section.
I was able to get JS errors to zero but still not working. Any help is greatly appreciated!
It appears you had an older version of the file: jquery-blockui-formprocessing.js
I updated it to the latest and the page works now. If you reinstall Data Bridge it should update to the latest.
wdtp.com
Thanks for the help but I'm not sire it's fixed.
I uninstalled DeignExtender and reinstalled and then removed and reapplied the Progress Bar on the page but it still has the old version of jquery-blockui-formprocessing.js. I even tried uninstalling all WebAssist extensions and reinstalling with no effect.
I did a search in my Configuration folder and found two instances of jquery-blockui-formprocessing.js and manually replaced them with the newer version. That seemed to work.
Is this ok or is there something deeper going on I need to fix?
It may not overwrite the file if it already exists. Your solution should be fine, and it should use the new version when applied on new sites.
