error with add content / insert content to or from powercms...
i am tryinng to add content to or/ and from power cms; it seems i can't connect to it
This implies an issue with your site settings in Dreamweaver. Go to the Server settings area and confirm that the server that is checked as the "Testing" server is set up correctly. Make sure the server ftp settings work and make sure the root folder and url settings are correct.
Send a screen shot of that page as a private attachment if you are unable to find the problem.
