So I'm getting the following error after I loaded my site to my server, "Error in SQL syntax." I checked with my hosting provider, Hostmonster, and confirmed that they support MYSQLi. I built my php coding off the folowing tutorial, https://www.youtu
Thread began 5/25/2015 10:50 pm by jamel | Last modified 6/02/2015 2:23 am by Ray Borduin | 1408 views | 17 replies |
jamel
So I'm getting the following error after I loaded my site to my server, "Error in SQL syntax." I checked with my hosting provider, Hostmonster, and confirmed that they support MYSQLi. I built my php coding off the folowing tutorial, https://www.youtube.com
The issue seems to only affect the pages that link back to my database on my hosting site. Everything worked correctly when it was in the dreamweaver enviornment using wamp, I did not start having problems until I uploaded the site to the server.
jamel
update
So when I remove the MySQLi Recordset on my pages, they come up fine. So it looks like the error is in that portion. I am new to php development and MySQLi. I am using the extension for dreamweaver that I bought a few weeks ago and my primary means of establishing the server behavior is through the webassist GUI for the extension.
It could be issues with the database connection information being different on the live server, or perhaps the tables weren't exported properly.
If you give me FTP access to the server and a link to the url where I can view the page with the error I can debug it more carefully.
jamel
See private message.
It looks like the database connection is failing. The database server, username, or password must be wrong for the live database.
I have added debug code to line 18 to show the error. You can delete that line once it is resolved.
jamel
To which page did you add the code?
userRegistration.php
If you visit the page you will see the error with other information about the connection.
jamel
Okay, I see it. I'm wondering how much of that has to do with the fact that the connection is set up to have the "localhost" reference an ip address.
Localhost usually works for most hosting companies. If you visit phpMyAdmin, the correct server name and correct database will be listed on the top of the page (see screen shot)
Don't include the part after the colon, that is the port and not part of the server name.
jamel
That worked. I had to use the ip address when I was running it as my test server, but once I changed the localhost from the ip address to the words everything started working just fine.
But I have one more question. For my login page I have it set to successful redirect to account.php, but it seems that when I click on "log out" (connected to server behavior) that if I were to login again it takes me to whatever the last page I was on inside my website. Do you know why this happens? Also, the pages that show when you login should be restricted only to be viewed when you are logged in, but I can put in the URL to the site and access the pages without being logged in.
Thank you for you help, I really appreciate it.
