DataAssist Search form problems
I have a basic DataAssist results page with a search box on the results page but it's not working as it should - when you search, it initially says no results found but if you hit the Back button you get the appropriate search result. I also built in a Reset Search button (I've done this on a few pages already with no issues) but it's not working at all, just does nothing. The page is based on other very similar pages I have that do work correctly and I've made sure the PHP code blocks are in exactly the same order as on pages that work fine, so can't think what else to try.
