date_format doesn't work the same
Thread began 5/15/2015 6:05 am by Sweens | Last modified 5/15/2015 2:17 pm by s.joiner74419001 | 271 views | 1 replies |
Sweens
Hi
Part of a select statement is:
DATE_FORMAT(pages.StartDate, '%%W %%D %%M') AS StartDate , DATE_FORMAT(pages.StartDate, '%%H.%%i') AS StartTime , DATE_FORMAT(pages.EndDate, '%%W %%D %%M') AS EndDate, DATE_FORMAT(pages.EndDate, '%%H.%%i') AS EndTime,
This works fine with MySQL, but on a page where I'm trying MySQLi, I get the following displayed on the page:
%W %D %M %H.%i
instead of
Friday 15th May 19.00 - 01.00
The code on the page is:
<?php echo $rsEv30->getColumnVal("StartDate"); ?>
<?php /*START*/ if ($rsEv30->getColumnVal("StartTime")<>"00.00"){ ?>
<?php echo $rsEv30->getColumnVal("StartTime"); ?>
<?php } /*END*/ ?>
<?php /*START*/ if ($rsEv30->getColumnVal("EndDate")<> $rsEv30->getColumnVal("StartDate")){ ?>
- <?php /*START*/ if ($rsEv30->getColumnVal("EndTime")<>"00.00"){ ?>
<?php echo $rsEv30->getColumnVal("EndTime"); ?>
<?php } /*END*/ ?> <?php echo $rsEv30->getColumnVal("EndDate"); ?>
<?php } /*END*/ ?>
Do I need to alter the query in some way?
Many thanks
Chris
Sweens
I've found the answer:
Dreamweaver puts in the following:
'%%W %%D %%M'
If I change it to
, '%W %D %M'
All works fine.
I happened to discover this when using a REPLACE to replace spaces in images with %20 - DW put %%20
