Content Added Disappearing From Site
Thread began 5/12/2015 1:11 pm by Kyle | Last modified 5/27/2015 1:02 pm by Ray Borduin | 1125 views | 5 replies |
Kyle
I am working on a new site and installing the CMS and when I hit the add to CMS button, it goes through the motions and doesn't produce an error. After I put the page online, the CMS content disappears. The only way that I can make it work is by coping to code into the CMS first and running the Insert From CMS command. I can handle that, but then I cannot get it to where my client can update the SEO tags. I will attach both the server information and CMS Login info.
Kyle
Do you have your site configured in Dreamweaver so that it uses the live remote server as the testing server? If not, it might be inserting the content into your local database and that could be why it doesn't show up on the live site.
Where are you getting stuck when trying to get the SEO tags editable?
Kyle
See attachments for configuration. I have it set to both.
The same thing is happening in the SEO tags. I will run the program and it will not show up in the admin panel. The title tag will also just appear as the web address in browser.
Please post a US phone number or Skype contact information and I'll give you a call to help you debug what is going on. It appears you have it set up correctly, so I'll need to do screen sharing in order to investigate it further.
Kyle
See Private Message
When adding meta data or title to the CMS system, make sure you don't highlight the tag surrounding the content, just the interior text. That was the problem in this case, the entire <title> tag was selected during application instead of just the title text.
