action buttons at bottom of cart (Continue Shopping, Clear Cart, Update, Checkout) have disappeared
Thread began 5/12/2015 3:35 pm by marsha431457 | Last modified 5/13/2015 1:10 pm by Ray Borduin | 378 views | 3 replies |
marsha431457
I used display manager to add items to several cart columns and now all the action buttons at the bottom of the cart (Continue Shopping, Clear Cart, Update, Checkout) have disappeared, also the special instructions field i recently added. I looked at fix we did before on this but that fix does not seem to apply to the current file (see attached).
May have just figured this out: the display manager had "email friendly cart" chosen, which I guess was from the last time I edited the blank_2.php template page for the custom email receipt (didn't notice that at first, would've thought it would keep the info for the cart_static.php which I was editing).
Did the above and now it's really screwed up.Then tried to restore from our backup from earlier today. It now looks like something we had ages ago before I made many many changes. Am really at a loss...
cart_static.php
Yes, this is an email friendly cart design, which wouldn't include form buttons.
The display manager isn't re-entrant. After running the wizard you have to make updates using Dreamweaver or basically you would be overwriting and re-generating the cart from scratch. It remembers the settings from the last time it was applied but can't work for inspecting and editing a previous application you are basically overwriting it if you run the wizard again.
I'd suggest getting a backup of the cart file ( I think you have one attached to a previous forum thread here) and then tell me what you are trying to change and I can walk you through making the necessary updates outside of the wizard.
marsha431457
Now have restored to what we did on May 6th when we finished adding instructions and customer contact info to custom email receipt. There were four files that needed to be restored along with the cart_static. It is working properly and now I need to get my info organized so I can tell you what I need to do to change the cart display so you can help with that. I need to add several fields in 3 columns of cart: Color, Logo, and Inscription. They are additions to the double tags add to cart button.
I have added to a test page (and the cart object) but need to add to cart display:
Tag2Color
Tag2Line1 (or Tag2Inscrition)
Tag2Logo
Tag2Side2Line1 (or Tag2Side2Inscription)
Then i must decide if it is necessary or preferable to redefine those same fields which are already in this form by adding "Tag1" to them. (for example "boh_4_Tag1Color_Add" instead of "boh_4_Color_Add").
cart_static.php
tags_double.php
Just go to the "Bindings" panel and you can drag/drop the new fields where you want them displayed.
You can also just type to update text in dreameaver to update the cart display where you need it.
