File Manipulation Upload doesn't work
Hello, can you check for me why File Manipulation Upload doesn't work?
I use in combination with Insert Single Record behavior.
It looks like it would work. Try adding this to the page and see if there is an error message after you try to upload the file:
<?php echo $WA_DFP_UploadStatus["WA_UploadResult1"]["errorMessage"]; ?>
Thank you Ray.
The upload now worked after I reinstall the extension and reapply it.
