sitewide search
Thread began 4/13/2015 8:15 am by Jamie | Last modified 4/14/2015 11:01 am by Ray Borduin | 2157 views | 6 replies |
Jamie
sitewide search
Hi Ray
Am trying to put together a sitewide search for the front end of a site and have a question and an issue
1. the issue is that when I click submit on the search form, the result page errors with this:
Warning: mysql_query(): Unable to save result set in /home/motlemso/public_html/clients/template/search.php on line 81
MySQL client ran out of memory
2. when I do get the above working, how do I actually echo the results on the results page?
Have attached the file
Cheers
Jamie
How many results does that recordset return? It looks like you may be trying to load too much data into the page at one time. What are you doing with that recordset? Do you need all of the rows?
Run that query in php myadmin... how many rows does it return? I think you might need to optimize that query or at least limit the number of results to use it on a web page.
Jamie
at the moment the database is almost empty as its a fresh install. have run the query in php myadmin and its showing 29 rows ( http://prntscr.com/6tcnf4 )
I appreciate that as the db grows that this will increase considerably, so what would be the best way to optimise the query? what would the 'best practice' be for creating full searchability for a visitor?
jon211112
I think that query is wrong... it is written to return results exponentially... The screen shot shows that your query is returning 1.5 million results. That is too many results to load into the page at one time.
Jamie
thanks jon... i was looking at the row number rather than the quantity returned and I can see that that would be far too many. I guess that would defintiley mean my query is wrong, but what would best practice be to achieve a sitewide search facility?
I'm thinking you want to use a UNION SELECT maybe... It is hard to say without understanding what the tables are being used for and what your intention is. Possibly separate recordsets for each table. I just don't know enough background about how the tables are used and what exactly you are trying to achieve. I can only say that the recordset you are creating is almost certainly not the right way to do it.
Jamie
OK, I judt thought it would be a question of setting up the search wizard as I have done so that a visitor could search the entire sites content. Having not done a site search before, just not sure what the best practice is to achieve it.
Will revisit when I need to implement this as I was just playing around with it to see what it could do
Cheers
Jamie
