checkout wizard check list
in the checkout wizard solution recipe for ecart...
start.htm
the print button to print the flash paper document appears to be disabled.
is it possible to access this document anywhere else?
start.htm
Thanks for alerting us to this. It looks as if one of the more recent Flash Player updates is causing the print button to be disabled. We're looking into fixing this.
In the meantime, I've created a PDF version of the file which you can access here ecart_checklist.pdf.
-Neil
