problems updating a page with password protection and file download
You kindly helped me create a web page that has a password field that then shows a region with a
button to download a pdf file. I was able to get it to work with a sample password and a
sample pdf to download.
Now I need to change the password and the pdf file. I changed the password and the pdf
filename and uploaded everything to the server. But the page is not working. I enter the new
password and it doesn't show the pdf download region.
I made changes to SecurityAssist password rule dialog box. Also went to File Manipulation to
change the pdf filename in the download dialog box. I took a look at Cookie, set session value,
but wasn't sure if I needed to make a change there.
Thank you for your advice.
