Cannot Uninstall 2.0.1 to install 2.0.2
Thread began 8/29/2009 4:17 pm by richmattheisz366791 | Last modified 8/31/2009 12:41 pm by Jason Byrnes | 897 views | 1 replies |
richmattheisz366791
I am having trouble uninstalling CSS Menu Writer every time there is a update. Previously I have been able to do it eventually after trying anything I can think of but not this time. The message I get is "The file C:\Users\Rich\AppData\Roaming\Adobe\Dreamweaver9\configuration\Shared\WebAssist\CSSMenuWriter\presets\Midnight\CaboSunset\menu_bg_l.jpg' is being used by DreamweaverCS3. Please close Dreamweaver CS3 and try again." The application thinks Dreamweaver is open for some reason and tells me to close Dreamweaver but it was never opened because I did this with nothing open.
Can you tell me what to fix?
After unsuccessfully trying to uninstall the extension (in VISTA) the uninstall process has caused an error message to appear when I open Dreamweaver now. This message is C:\Program Files (86)\Adobe\Adobe DreamweaverCS3\Configuration\Shared\WebAssist\CSSMenuWriter\Library\Shared_ser.js(error3)
Any Help Would be appreciated.
make sure both Dreamweaver and the Extension Manager are closed, then try manually deleting the file:
C:\Users\Rich\AppData\Roaming\Adobe\Dreamweaver9\c onfiguration\Shared\WebAssist\CSSMenuWriter\preset s\Midnight\CaboSunset\menu_bg_l.jpg
After that, try uninstalling the extesnion in the extension manager again. If all else fails, try renaming the configuration folder at:
