ECart and TransFirst
Can I use ecart with the following payment gateway?
http://www.transfirst.com/online-processing/payment-gateway
You can, but you would have to do the integration for the actual payment following their documentation directly.
This is something we can help you with in a premier ticket as well. It usually can be done in an hour or two depending on how well the payment gateway documentation is written and the example available.
I'd suggest using authorize.net when running the eCart checkout wizard and then you would just update the authorize.net checkout code to use the new payment gateway. It would just be one section of code on the confirm.php page.
I will secure the documentation and share shortly and yes I will do a premiere for this one.
http://www.transfirst.com/solutions/ecommerce-processing/shopping-carts
I think this is where the technical information is.
Can you let me know if this gateway will work as per your help and guidance via the premiere support?
Thanks Ray
Any gateway will work. They just called me and it sounds like they will have a technical person on their side call me to work on it with me directly.
Just finish your site and get it all set up with authorize.net. Then in the support session I can work with them to update authorize.net to the new gateway.
Once you have your site all set up with the authorize.net gateway, request a premier ticket and I'll call you and verify you are at a good point and take payment. Then we can schedule the meeting with their tech to finish.
