DataAssist search_page has no properties
Had some issues with DataAssist recently. I'm using the wizard to create some management pages for a custom CMS. I'm running Adobe DW CC (2014.1.1 / 6982) and DataBridge 1.2.2 with Adobe's Deprecated Panel Support on OS X Yosemite 10.10.3.
I can get all the way through creating all my pages via the Wizard, but when it runs through the process of creating the pages it stops at the Results page (after creating the Insert and Update pages) with the attached JavaScript error message.
After mucking around with this for a while and creating five different Applications I found one that worked, which is the only one that included a Search page. The other four didn't work as I hadn't set up Search pages for them. I've since solved the issue by creating a simple Search page for each, but obviously there's an issue with that (in that I then need to delete that page as I don't need it).
I've tried resetting the Workspace, deleting the extensions, adding them again, removing the Cache, restarting the machine, but it doesn't seem to shake the problem.
