Identify item just added to cart.
Thread began 3/30/2015 1:50 am by enquiry272230 | Last modified 3/31/2015 9:56 am by Jason Byrnes | 693 views | 3 replies |
enquiry272230
I have a repeat region with multiple "Add To Cart" buttons on the page.
After adding an item to the cart, the page redirects to itself.
I want to trigger a shadowbox html page on redirect to the page based on the item that was just added to the cart.
( I have a shadowbox working already from a link in the repeat region near the "add t cart" button to display recommended items for that item.
Is there a way to identify the ID or name of the item just added to the cart after redirect, so I can use it to trigger the shadowbox automatically based in the item just added?
Hopefully I have explained this OK
when an item is added t the cart, it is added at the end. you can use the move last function to get the last item in the cart and get it's ID:
$cartName->MoveLast();
echo($cartName->DisplayInfo("ID"));
$cartName>MoveFirst();
enquiry272230
Thanks Jason, I believe I can use this in conjunction with a copy of the Add To Cart form post.
e.g. To get the item ID only after Add To Cart is used and not when page loads normally.
if (isset($_POST["eCart1_1_ATC"]) || isset($_POST["eCart1_1_ATC_x"])) {
$eCart1->MoveLast();
echo($eCart1->DisplayInfo("ID"));
$eCart1->MoveFirst();
The above works as required to just get the ID. It's a start.
I think I will be able to make up a line of code to automatically display the shadowbox with the recommended items based on the item's "ID" and if an "ID" is present.
So far so good, thanks again.
you're welcome.
