Paypal credentials from Database
Thread began 3/26/2015 1:38 am by enquiry272230 | Last modified 3/30/2015 12:14 pm by Jason Byrnes | 238 views | 3 replies |
enquiry272230
HI,
I have a CMS I've built and it's used by a few customers with various modifications.
I have added the cart with eCart 6
I would like the Paypal Express credentials to be served from the database so it's easy for the customer to change and update.
Details in private message
Your advice is appreciated.
add the recordset on the gateways.php, then code the variable bindings to use the recordset results:
$WA_PayPal_PayPal_API_Username = "".$row_RecordsetName['API_UserName']."";
you will need to adjust the sample code above to use the correct recordset name and column name.
enquiry272230
Thanks Jason. I had it set up that way at first, thanks for confirming I was on the right track
The problem was Dreamweaver had set up the database connection in gateways.php as a locally referenced file.
Because gatelways.php is an include file in confirm.php and pp_confirm.php, I had to correct the database connection.
Was:
<?php require_once('../../../../Connections/BusyCMS.php'); ?>
Should have been:
<?php require_once('../Connections/BusyCMS.php'); ?>
All good now, thanks for your help
glad to hear it is working.
