Powerstore - Change Hompage and Lock'er Down
Thread began 3/24/2015 5:56 pm by SPT | Last modified 3/26/2015 12:38 pm by Jason Byrnes | 573 views | 3 replies |
SPT
Hi Jason,
I need to make the index.php powerstore homepage not the homepage. Homepage will be separate from Powerstore with a link to login or register..
I notice if I rename Powerstores index.php it does not show content anymore.
Then I have a couple of other things I need to do.
1 - Lock the pages to registered users only. I believe I can do that with Security Assist workflow (will see after I change index to different page).
2- I need for registrations to be approved by my client.
If these things are beyond our scope to sort out on this forum I can pay the $99 for premium support.
your host should offer a way to define the default home page name, either using .htaccess or another method.
you should contact the hot for a way to change the default page from index.php to home.php or default.php.
looking down the pages should be easy enough with Security Assist, but approving registrations will take some custom coding through premiere support.
SPT
Genius!!! The idea to use .htaccess - I would not thought of that.
I will sign up for premiere support to sort out the registration approve jobby.
Thanks....again and again and again for all your great support!
you're welcome.
