Use the Checkout Wizard to make changes.
Thread began 3/24/2015 5:56 pm by bob402889 | Last modified 3/25/2015 12:06 pm by Jason Byrnes | 128 views | 1 replies |
bob402889
I setup check out pages with the Checkout Wizard. How use the Checkout Wizard to make changes.
The checkout wizard cannot be used to make changes, it is a creation tool only. It is not intended to make edits.
if you want to change the settings that where applied by the checkout wizard, you either need to edit the server behaviors that the checkout wizard added to the pages, or delete the checkout pages and rerun the checkout wizard.
