Using column/DIV formats inside Power CMS HTML Editor
I'm creating layouts for a client that will be utilizing side by side DIVs, so they're mobile device compatible. How do I accomplish this within the HTML editor in Power CMS admin?
Thank you.
Thank you.
apply the appropriate class to the dive, and make the class is defined in the CSS files attached to the page.
I'm thinking that might get complicated for my client. Maybe I could get the same effect if I used a table with a 100% width. That should scale appropriately in mobile devices, right?
Will this feature ever be added in the future - the ability to create columns within the HTML editor?
Thank you.
I've found some good tutorials for making tables responsive, so I don't think I need to worry about columns just yet.
Creating columns is not really the job of HTML Editor, it is more the job of the Style sheet you create and applying the styles as needed.
Yeah, I know ... I'm just thinking of how it's done in Wordpress. :)
