Add To Cart Button query
When placing my eCart Add to Cart Button, I have put in the Redirect field the actual shopping cart, ie 'cart.php' which is the same as the actual Cart field (see attached screenshot). Is this going to create problems?
I'm not sure i understand the question.
in the Redirect field, you should enter the page that you have added the cart display to that shows the contents of the cart.
Oh ok. I was just a little thrown by the tutorial which is redirected to cart_static. I am indeed pointing it to the page that has the cart, simply called cart.php. I understand now that this would be the correct thing to do
Many thanks
