Activation
Trouble getting extensions to work today. (Australia 1.09 pm) reinstalled everything, reset activations, now activations are declined.
Have you got issues with the activation system?
Webassist Activation now back up, all good.
Greetings,
I am trying to activate my Web Assist tool, but continue to have problems. I have uninstalled and re-installed the software and that seemed to go fine. I exited DW and went back in. Now when I try to access an entry on the Web Assist menu DW 2014.1 CC on a Win 7 x64 English lang system hangs and becomes unresponsive. I have to use Task manager to cancel DW. Eventually I got a dialog to send additional information to MS about the program stopping.
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
Then close Dreamweaver and Delete the Dreamweaver Cache file from the users configuration folder:
I can't activate my ecart is there still problems have lastest version just reinstalled in case
I was able to reinstall and activate with that serial number. It could be an issue with a firewall or antivirus software. Possibly an issue with the Dreamweaver installation. Are you able to activate other webassist extensions, or do you always get the same error?
Ok i had time to do this now, it not letting me activate none of the products it ask me for the activation code on everything, also I tried this now at work same thing with dreamweaver cc on windows 8 and windows 7, something is wrong because its happening to me on 2 different computers.
I get that my passwords are incorrect
Go ahead and contact me on Skype later this week and I'll do screen sharing to investigate this with you.
