Validating custom date field
Thread began 3/05/2015 8:04 pm by bjgarner241692 | Last modified 3/11/2015 12:33 pm by Jason Byrnes | 1337 views | 17 replies |
bjgarner241692
I have altered DatePicker to format my date with M-dd-yy at my customers request but I have an
issue now with my WAValidations. It expects the date to be mm-dd-yy. Changing it to validate
only that there is text is not adequate.
Can I change this line: $WAFV_Errors .= WAValidateDT((isset($_POST["dob"])?$_POST["dob"]:"") . "",true,"","","",false,"","","",true,11);
to check for the custom date format?
try converting the date format:
$WAFV_Errors .= WAValidateDT((isset($_POST["dob"])?date('m-d-Y', strtotime($_POST["dob"])):"") . "",true,"","","",false,"","","",true,11);
bjgarner241692
Thanks, that will get me close. I thought maybe the code would go in one of the "" spaces towards the end.
When I post your code exactly it does not validate.
I edited to math the formatting on my date picker and it still will not validate. Is it possible that the format I have used is simply incompatible with WAValidate?
Here is my datepicker
$(function(){
    $('#dob').datepicker({
        changeMonth: true,
        changeYear: true,
        maxDate: 0,
        yearRange: "-100:+0",
        dateFormat: 'M-dd-yy',
        onClose: closeDatePicker_dob
and here is the validation line I tried in addition to your suggestion
  $WAFV_Errors .= WAValidateDT((isset($_POST["dob"])?date('M-dd-yy', strtotime($_POST["dob"])):"") . "",true,"","","",false,"","","",true,11);
M-dd-yy renders a date like Mar-6-2015 which is what my client requires.
I have included the full page in the PM section.
Thanks.
try changing:
$WAFV_Errors .= WAValidateDT((isset($_POST["dob"])?date('M-dd-yy', strtotime($_POST["dob"])):"") . "",true,".*","","",false,"","","",true,11);
bjgarner241692
Thank you, but I still get the same error. The field will not validate.
bjgarner241692
I have changed the validation line to simply require.
$WAFV_Errors .= WAValidateRQ((isset($_POST["dob"])?$_POST["dob"]:"") . "",true,11);
and I still am not able to validate anything except dd-mm-yy.
I verified that there as not a cache issue by making a small visible change to the live page. As soon as I pick the date using the datepicker the box goes red and the page will not submit.
Very frustrating. I don't understand how the date format even applies now.
bjgarner241692
I found the line where the real problem is:
var dob_Spry = new Spry.Widget.ValidationTextField("dob_Spry", "date",{ format:'mm/dd/yyyy' , validateOn:["blur"]});
When it would not validate on a simple "Required" but still threw the same error it made me look deeper. I actually removed the validation entirely and still got the error but removing the WAValidation does not remove the Spry code at the bottom of the page.
If I change the format there to M-dd-yy it still fails.
If I remove that line entirely the page will submit but the line is not validated at all.
Spry is a Dreamweaverr validation method and not tied to the WA Server Validation.
In actual fact, spry has been deprecated by Adobe.
I wold Remove the spry validation but keep the server side validation ion place.
bjgarner241692
That is exactly what I did in the end, but now it does not validate at all. I can type anything in that field and it will pass.
Aside from that, I did not put the Spry Validations on the page. They simply appeared as I added the WAValidations and the Validation ShowIf. As far as I know, the Spry code appears along with the WAValidation code. There is a SpryValidationText entry for each WAValidation that I added to the page.
Spry validation may be added if you use form builder to create the form, but will not be added simply by adding server validation.
if you have Data Bridge, you should install the newest version which replaces Spry validation with JQuery validation.
