DataAssist Search behavior and Timestamp column
Thread began 3/05/2015 9:43 am by MagsW | Last modified 3/05/2015 4:08 pm by Jason Byrnes | 1097 views | 5 replies |
MagsW
I have the standard DataAssist results page with a search form on it. A new column has recently been added to the database which is in Timestamp format i.e. yyyy-mm-dd hh:mm:ss although the time is not required. I rebuilt the Search facility but I've found that if I search on this field for a certain date, it doesn't work. I tried running a query directly on the database and discovered that using the following query gives zero results:
SELECT * FROM clients WHERE DateAdded LIKE '2015-03-05'
However if I add a % to the date it returns the correct results:
SELECT * FROM clients WHERE DateAdded LIKE '2015-03-05%'
My question is, where do I add that % on my results page so that the search function will work properly, or is there another way I can force the search to ignore the time part of the field?
MagsW
Hi Jason, see PM section. The Staging Date column search works fine (DATE format column) but the Date Added search (TIMESTAMP format) doesn't - it should return around 190 results if you search for today's date.
couple of problems:
1) Date elements do not work properly with using includes as the search
2) The date form you had for the data added search form element was not valid, i changed it to use mm/dd/yyyy
so to get around the issue with dates and like searches, I changed the search type to = and added code to format the date:
$WADbSearch1->addComparisonFromEdit("DATE_FORMAT(DateAdded, '%Y-%m-%d 00:00:00')","DateAdded","AND","=",2);
MagsW
That's great Jason, many thanks indeed!
you're welcome.
