Dynamic Dropdowns in CC
Thread began 3/03/2015 2:57 pm by wyncole | Last modified 3/11/2015 3:35 pm by wyncole | 2382 views | 10 replies |
wyncole
I'm going through the Getting started with Dynamic Dropdowns tutorial but don't see the "insert->Forms-> list/menu item. I'm using CC, did it's location change? thanks, Wyn Cole
In DW CC, it is:
Insert -> Forms -> Select
to insert a select list.
wyncole
OK,
I got that, maybe I don't understand what I'm trying to do. I have created a form using Data Bridge and want some of the fields to use drop down lists. Let's say I want the Type field to be feed by the database or populated by a list from within the page. I don't see how this tutorial addresses that. I'll send the file so you can see what I'm talking about.
Thanks,
Wyn
to have the type filed fed from a database:
create a recordset for the table to use to populate the type field.
replace the type field with a select list, make sure to use the same name.
in the property inspector, click the dynamic button, and set the recordset to use to populate the list, and set the column to use for the value and the column to use for the label.
wyncole
Dynamic button will not activate
I'm following you instructions but the Dynamic button is doing nothing. I'm assuming that the new "Select" List is to be selected when I open the Property Inspector.
If this doesn't work, can I achieve the same effect by populating the list values from the Properties Inspector?
Do you have the deprecated server behaviors extension installed?
http://www.webassist.com/tutorials/Deprecated-Server-Behaviors-for-Dreamweaver-Creative-Cloud
this needs to be installed for the Dynamic button to function.
wyncole
Dynamic buttons
OK,
I'll try that and get back to you.
wyncole
Unexpected file format error
That doesn't seem to work either. I get a Unexpected File Format error.
Do I need MySQLi Server Behaviors installed as well?
Please provide a Skype username or a US phone number and a good time to contact you when you will be in front of your computer and we will have an engineer contact you to resolve this issue over the phone.
We are available Monday - Friday from 9am - 4pm EST (except major U.S. holidays).
wyncole
Skype contact
wyn.cole
I'm on Central time so 2:00pm my time should work. Let me know if a little later would be better for you.
Thanks,
Wyn
