eComm with eCart 6 video
Hi guys,
The site says I should have free access to the video (http://www.webassist.com/product/ecommerce-webinar-2) with an eCart 6 purchase. It is only available as an upgrade in my account for $49?
Hi guys,
you should be able to access the webinar on the eCart 6 download page.
open the eCart 6 download page and scroll to the webinars section for the link.
Thanks Jason,
I expected to find it in the same place as other purchased webinars in my account.
since it's included with eCart 6, its a part of the eCart 6 download page.
Videos not compatible with Safari?
I have the plugin installed and all the security settings as suggested.
The video uses Adobe Connect. I Find Adobe Connect is hit or miss with Safari, it works more reliably with Fire Fox.
No luck on two different computers with Safari, Chrome or Firefox ..... yet I use connect at least three times a week (since as long as I can remember) for other webinars without any issues at all.
Why were they recorded that they would have to be set to unsafe mode?
The Webinar Takes a little time to load, My Last test i clock it at taking 2 minutes. After the initial browser window opens, it should try opening the Adobe Connect window in a separate window. after that opens, it will need to download the webinar before it starts playing.
As for needing to run Adobe Flash in un-safe mode, that is not a matter of the way the recording was made, but rather a limitation to Flash in Safari. In safe mode, adobe Flash cannot access the connect add in. see the following quote from adobe:
http://www.adobe.com/go/learn_fp_safari_safe_mode
