mysqli server not found
Thread began 3/01/2015 1:07 am by jamie424562 | Last modified 3/02/2015 12:21 pm by Jason Byrnes | 1851 views | 5 replies |
jamie424562
hi there
have added a recordset and try to modify it, then receive error that the hosting/testing server isnt available. keep getting this even thou the server is available and working just fine. one minute i can add then i cant. keep restarting dw and deleting cache file then it may work and it may not work.
this is kind of annoying, the server is therer i can access the pages fine and even add a recordset at times.
in your Dreamweaver Site Settings, are you using a Local testing Server or Remote server?
If using a remote server as the testing server, you should contact the host to determine why the MySQL server is intermittently not available.
jamie424562
thats as a local server :) wamp....
Its weird because it displays the database fine if I open the designer, but then within the standard query editor it wont even display the database and then again its intermittent. Each time have checked if the server is working which it is so thats not a problem.
What is your OS?
What version of DW?
What version of MySQLi is installed?
Do you have other extensions installed? if so what are the versions?
can you send a screen shot of the error please.
jamie424562
windows 7, with all updates.
DW CC
The latest version of mysqli from your site, same applies to databridge, ecart and extender, all of which had been re-installed with the latest versions available here. Plus some DMXzone plugins.
Remove and Install again I guess is what your going to suggest next so I will go ahead and try that tomorrow. and post back here once completed.
i had also asked for a screen shot:
