How do i fix image size issue?
Thread began 2/27/2015 12:28 pm by willo009412397 | Last modified 3/05/2015 8:58 am by Jason Byrnes | 1152 views | 5 replies |
willo009412397
Hi i have an issue with the way Dataassist handles Images on both Results and Details pages. If i have an image that is long and is meant to be viewed that way its fine. But if i have an image that supposed to be viewed stood up it just stretches and blurs the image. How do i get around this? i did notice that when added to Cart the images align in the right way, but looking into the code and css for the Cart i couldnt see anything that did this. I thought maby i could use some of the same code but there was noting i could use. Hope i explained this ok. You will understand more when looking at the attached image files . . .img1 is fine but img2 is stretched??
Jamie
Hey
You may want to check out this tut using image Resizer http://www.webassist.com/tutorials/Getting-Started-with-Image-Resizer
Hope it helps
Jamie
willo009412397
True Jamie but this would require me to purchase the extension data bridge? i think its called, as they do not now sell the extensions on there own, but bunch them together. And i do not have the amount to buy this. I was just wondering if anyone had any code i could impalement to male it work..
theres probably both a width and height set for the image, try editing the image to only set a height
anonymous
Thanks Jason thats kinda worked, i think i need to up grade my extensions. I will be buying Databridge when i get paid next week. Will the image re-sizer do what i am asking? for future projects
image resizer will dynamically resize the images. it has an option for fit to box which allows you to set a specific box size, and portrait images will be resized by height to fit the box, and landscape images resized by width to fit the box.
