With my host server I have to delete the 'dynamic SQL connect' and recreate a standard plan 'mySQL connection'. Then it worked fine.
Sounds like you are trying to use a MySQLi connection with the standard DW Recordset dialog box or vice versa.
If the Connection is a Dynamic MySQLi connection, use the MySQLi recordset dialog that is under webassist -> MySQLi -> MySQLi recordset.
