Javascript error message
This is an existing site that has worked for quite a while. I can't do any edits now in the shipping flat rate or inserting a new add to cart button. Please see screen shots of the errors.
have you tried:
reset the workspace layout:
go to Window -> Work Space layout -> Reset '<your layout name>'
Then close Dreamweaver and Delete the Dreamweaver Cache file from the users configuration folder:
I did the cache trick but not the reset layout. I'll try that.
No luck. Same error message. I reset layout. Closed it down. Dumped the .dat file. Repeated when first didn't work.
A while ago, I had an issue and you sent me a replacement file.
http://www.webassist.com/forums/posts.php?id=35582
I'm asking Ray to have a look, I will let you know when I hear back fro him.
Ray said he would give a call to look into this with you.
Thanks Jason. Ray did phone and it is straightened out. It was a bad install of eCart. All good now.
glad to hear it is working.
Well, not yet. The error message isn't getting thrown out but I can't get the add to cart button to actually work. See PM please.
