URGENT - can't login to SecurityAssist protected pages since PHP upgrade this evening
Thread began 2/16/2015 3:15 pm by Mags | Last modified 2/16/2015 3:54 pm by Mags | 1274 views | 3 replies |
Mags
Please help! Our client is demonstrating their website tomorrow morning to over 400 people and there was a PHP upgrade on the server earlier today. I've just discovered that I can no longer login! I turned on error reporting and got the following message:
Warning: Unknown: open(/var/lib/php/session/sess_k3adndpmhn7nkd3r5m4vvsdj13, O_RDWR) failed: Permission denied (13) in Unknown on line 0 Warning: Unknown: Failed to write session data (files). Please verify that the current setting of session.save_path is correct (/var/lib/php/session) in Unknown on line 0
Can you advise what I should do?
Hi there, doing a quick scan on Google returned result where other users had same issues regarding the configuration of the hosting. Take a look at these links that hopefully will provide you with a solution on sorting the hosting out.
http://stackoverflow.com/questions/5104065/php-session-handling-errors
https://wordpress.org/support/topic/unknown-php-errors-bottom-of-bloghelp
http://forum.sp.parallels.com/threads/subdomain-with-fastcgi-php-sessions-not-work-chmod-777-var-lib-php-session-not-help.112600/
Best regards
Chris
Mags
Thanks for the quick reply - I've passed this on to our web hosts so hopefully they'll be able to sort it out.
Mags
The web hosts have fixed it - it was a permissions problem I believe. Thank god, I can go to bed now!!
