Rotate image in CMS
Once an image has been uploaded through CMS should I be able to rotate it 90 degrees right or left? I cannot find a way to do this.
In the file manager select the image, then look at the top right of the file manager window, there is a section labeled actions with an option to rotate clockwise, or counter clockwise.
I don't see that. could it be a version issue? I have attached images of what my edit screens look like.
click browse server to open the file manager.
in the file manager select the image then the rotate clockwise / counter clockwise option at the top.
