mysqli insert record returns "There is an error in your SQL syntax."
Thread began 2/12/2015 3:29 pm by markhaynes75235 | Last modified 2/13/2015 12:16 pm by Jason Byrnes | 2985 views | 6 replies |
markhaynes75235
I've got a prototype website that I'm working on. I'll send the URL in a private message. The home page has a Contact form in a mega menu that uses an AJAX Contact Form I got from Code Canyon @ www.codecanyon.net (I was unable to get Universal Email to work with a form in the MegaMenu layout, so I used the AJAX Contact Form instead. The form action posts to a contact.php page, and was working fine before I inserted the WA MySQLi Insert Record Server Behavior. When I apply the MySQLi Insert Record Server Behavior usng WA Form Data to enable accessing the external form on the megamenu on the contact.php page, then upload the files to my server (including the queryobj.php) on testing the contact form I get "There is an error in your SQL syntax" message, nothing else. I've attached the contact.php privately.
Thanks for your help as always
markhaynes75235
Originally Said By: markhaynes75235
to help troubleshoot, open the webassist/mysqli/queryobj.php file and enable debug mode.
change:
$this->Debug = false;
$this->Debug = true;
I Just tested your form and it seams you have it working now?
for me it showed the Email Sent Successfully message.
markhaynes75235
I was able to find the problem - I had added a field to the local db but forgot to add it to the remote one. Thanks for the pointer on turning on Debug. Meanwhile instead of loading the confirmation in the megamenu as it was doing before, I get a new page with the confirmation. See screen shot of the confirmation in the megamenu.
markhaynes75235
Hi Jason: I was able to get it to work by reloading the javascript file that controls the display. I've attached the one that was broken and the one that works for your edification. The jigowatt_bak.js is the one that did not work. the jigowatt.js works.
jquery.jigowatt.js
jquery.jigowatt_bak.js
ok, glad to hear you found the problem.
