backend functionality 'lost' moving to live server
Thread began 2/09/2015 5:11 am by Jamie | Last modified 2/10/2015 9:07 am by Jason Byrnes | 1826 views | 7 replies |
Jamie
Hey Jason
Rather bizarre, but I have moved a site from a live testing server (not localhost) to the live domain.
On the testing site the backend datepickers and update/insert redirects all work absolutely fine but on the live domain they dont. The datpickers arent dropping down when the cursor is inserted in the field, when inserting or updating content you dont get redirected to the results page.
Not sure what is missing or may have been uploaded incorrectly but have uploaded the site files 3 times now thinking that something may not have been put up but to no avail!
Any suggestions gratefully received and if you need access or the files themsleves just let me know
Jamie
Jamie
see PM
see PM
Jamie
hmm try attached
for the date picker, you are using your own jQuery files which are not compatible with the date picker:
<script type="text/javascript" src="../webassist/jquery/jquery.js"></script>
<script type="text/javascript" src="../webassist/jquery/jquery-ui.js"></script>
I changed that to use the google hosted versions:
<script src="//ajax.googleapis.com/ajax/libs/jquery/1/jquery.min.js"></script>
</script>
<script src="//ajax.googleapis.com/ajax/libs/jqueryui/1/jquery-ui.min.js"></script>
to fix the problem.
for the redirect, you had blank space in the connection file which was causing an error.
Jamie
thanks for that. bit odd as on the live testing server it works perfectly......
re your PM will take a look and try
Thanks again
Jamie
you're welcome.
