Updates removes \ character from field data
Thread began 2/04/2015 6:01 pm by Jack Stockton | Last modified 2/06/2015 4:32 pm by Jason Byrnes | 985 views | 11 replies |
Jack Stockton
I have a field on my form that contains the name of a SQL server, such as 10.169.1.139\GTS. When I use the generated update form the \ will be removed, so that it is now 10.169.1.139GTS. How can I stop this behavior.
What server behavior are you using for the update? Please include a copy of your page for us to review and we can determine the proper work around for this issue.
Jack Stockton
See attached file
what is the name of the form field that passes the \ character? you could use code at line 1 of the update page to convert the \ to \\ which is the escape character, for example:
if(isset($_POST["field_name"])) {
str_replace("\\","\\\\",$_POST["field_name"]);
Jack Stockton
How would I use that? Many of the fields on the form could have a \ in the data.
An example field with the problem is the DB_LX, it colud have the value 10.169.1.139\GTS in it.
<input id="DB_LX" name="DB_LX" type="text" value="<?php echo((isset($_GET["invalid"])?ValidatedField("AccountWebupdate","DB_LX"):"".$row_WADAAccountWeb["DB_LX"]."")); ?>" class="formTextfield_Medium" tabindex="21" title="Please enter a value." />
Would the $WA_fieldValuesStr have to be updated for each field?
$WA_AB_Split . "".((isset($_POST["DB_LX"]))?$_POST["DB_LX"]:"") ."" .
no, create a code black for each element at line 1:
if(isset($_POST["DB_LX"])) {
str_replace("\\","\\\\",$_POST["DB_LX"]);
Jack Stockton
What do you mean line 1.
I tried putting the code at the top and I tried before the generated // WA DataAssist Update code. Still strips \, but now an error
Warning: Cannot modify header information - headers already sent by
the very first line of code. line 1.
the headers already sent error means there is white space between php code blocks.
Jack Stockton
Okay no error, but the \ is still being removed. Here is the header
oops, sorry, i had incomplete syntax.
<?php if(isset($_POST["DB_LX"])) {
/* Workaround to support \ characters */
should be:
$_POST["DB_LX"] = str_replace("\\","\\\\",$_POST["DB_LX"]);
