Failed to create a search page (including results, update and details)
What is your OS?
What version OF Dreamweaver are you using?
What Extensions, including the version numbers are installed?
Window 8.1 Pro.
DW CC 2014 latest
Data Bridge 1.2.1
Is Data Bridge the only extension installed?
you should also have the Depricated Server behaviors extension installed:
http://www.webassist.com/tutorials/Deprecated-Server-Behaviors-for-Dreamweaver-Creative-Cloud
Did you have a previous version of Data Bridge installed before? or a previous version of other extensions?
I have the deprecated server behaviour, also ajatix advanced drop down, Before the current version, i had the DB 1.2.0
Did you uninstall the previous version before installing the new one?
it sounds like you had installed the new version over the previous version.
Locate the users configuration folder, for details see the following page:
when you locate the configuration folder, rename it.
then restart DW to recreate it and close DW. now open the extension manager, remove the extension and reinstall them.
Deleting cache files solved the problem, thank you
