SecurityAssist 50 members logged in at the same time?
Thread began 2/04/2015 6:53 am by Andre | Last modified 2/09/2015 12:59 pm by Jason Byrnes | 3146 views | 11 replies |
Andre
I am setting up a competition page. I want people to be able to create a user/login & enter the competition a number of times. I am using the SecurityAssist to generate the login pages & User controls. I could be in a situation that 20 or 30 people could be trying to login at the same time. Is there a way that this can be done? basically that i can have up to 50 members logged in at the same time?
So if i have 50 people logged in how do i get them all to see the competition page with a form & have the logged in persons details there?
I don't think I understand the question. There is no reason why 50 people couldn't log in at the same time without changing anything. Where exactly is this going wrong? It shouldn't be any different than setting it up so 1 person can register and log in.
Andre
I am new to this kind of thing & not sure if i am asking the correct question.
Where do the logged in people get redirected to?
I have 1 php document with the entry form on it so if i have 50 people logged in how can they all use the 1 entry form page?
Is there a way of setting up the entry form page as a template that when someone logs in it will make a page from this for the logged in person, so essentially as people register they will all have their own page?
the way that security assist login works is:
the user enters the username (or email address) and password, this is passed to the database to look up a record that contains the entered information.
if a record is found, the ID for that record is stored in a session variable.
in the security assist authenticate user behavior, you can set the page that they are redirected to on successful login. if you go to the session tab, you can also set other columns such as First name, last name to save to session variables.
on the success page, you can either use the ID session variable to create a recordset that contains the users specific data and display that, or if you set the login top save other columns to sessions, you can use those sessions to display the users information.
Andre
OK so if i set the redirection for logged in users to the competition page (this has the competition form).
Then i login (andre) & start filling out the form on the competition page.
At the same time you login (jason) & are re-directed to the same page?
How does that work?
each submission will be a unique submission.
when the form submits, you should also capture the User ID session that is created to tie it to the person who filled it out.
Andre
Jason 1 of us is misunderstanding how this works!!!!!!
What i am asking is if i only have 1 form page & 2 people are logged in at the same time, how is it possible if i only have 1 page?
So when i login & i am redirected to the form page & at the same time you login & are redirected to the same form page?
So essentially you & me are logged in at the same time how can we both fill out the form if there is only 1 form page?
we are both using different computers to access the form
a server can send the same page to multiple people at a time regardless of whether the user needs to login first.
when you visit can.com and view a news article, it is also being viewed at the same time by many other people.
this is no different from a form page.
now the key, is that when the form is submitted, you will want to collect information specific to the user who filed it in
when a user logs in, their is is saved to a session. when the form submits, you want to collect the session along with the form information.
Andre
Brilliant, so if i want the form to be automatically filled in with the logged in user details, name,email,phone.........
do i insert a binding in the form field for user details, name,email,phone......... ?
Like i said previously, when the user logs in, the ID is saved to a Session variable.
you can use that session as a filter in a recordset to return the logged in users information, and use that recordset in the form bindings.
this is similar to the way the user update page, that the security assist wizard creates, works. you can refer to that page for details.
