insert record and send email
Thread began 2/03/2015 5:32 pm by JBWebWorks | Last modified 2/08/2015 9:08 pm by JBWebWorks | 488 views | 3 replies |
JBWebWorks
I just installed Data Bridge 1.21 and i have a page with a form that inserts into database and should send email alert that new record has been inserted.
I have a redirect on the email send.
Problem I'm having is the insert works correctly and the redirect succeeds but the email is not sent.
My Code
if($_SERVER["REQUEST_METHOD"] == "POST") {
foreach($_POST as $key => $val) {
if(is_array($_POST[$key])) $_POST[$key] = implode(", ", $_POST[$key]);
?><?php require_once('Connections/connmpmga1.php'); ?>
<?php require_once("webassist/form_validations/wavt_scripts_php.php"); ?>
<?php require_once("webassist/form_validations/wavt_validatedform_php.php"); ?>
if (isset($_POST["submit2"]) || isset($_POST["submit2_x"])) {
$WAFV_Redirect = "";
$_SESSION['WAVT_index_500_Errors'] = "";
if ($WAFV_Redirect == "") {
$WAFV_Redirect = $_SERVER["PHP_SELF"];
$WAFV_Errors = "";
$WAFV_Errors .= WAValidateRQ(((isset($_POST["player1"]))?$_POST["player1"]:"") . "",false,1);
$WAFV_Errors .= WAValidateRQ(((isset($_POST["tee1"]))?$_POST["tee1"]:"") . "",true,2);
if ($WAFV_Errors != "") {
PostResult($WAFV_Redirect,$WAFV_Errors,"index_500");
<?php require_once("webassist/database_management/wa_appbuilder_php.php"); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
mysql_select_db($database_connmpmga1, $connmpmga1);
$query_rs_members = "SELECT * FROM members ORDER BY members.`Last Name`";
$rs_members = mysql_query($query_rs_members, $connmpmga1) or die(mysql_error());
$row_rs_members = mysql_fetch_assoc($rs_members);
$totalRows_rs_members = mysql_num_rows($rs_members);?>
<?php require_once("webassist/email/mail_php.php"); ?>
<?php require_once("webassist/email/mailformatting_php.php"); ?>
// WA DataAssist Insert
if (isset($_POST["submit1"]) || isset($_POST["submit1_x"])) // Trigger
$WA_connection = $connmpmga1;
$WA_table = "saturdaysignup";
$WA_sessionName = "signupID";
$WA_redirectURL = "";
if (function_exists("rel2abs")) $WA_redirectURL = $WA_redirectURL?rel2abs($WA_redirectURL,dirname(__FILE__)):"";
$WA_keepQueryString = false;
$WA_fieldNamesStr = "player_name|Tees|pairing_request";
$WA_fieldValuesStr = "".((isset($_POST["player1"]))?$_POST["player1"]:"") ."" . $WA_AB_Split . "".((isset($_POST["tee1"]))?$_POST["tee1"]:"") ."" . $WA_AB_Split . "".((isset($_POST["pairing1"]))?$_POST["pairing1"]:"") ."";
$WA_columnTypesStr = "',none,''|',none,''|',none,''";
$WA_fieldValues = explode($WA_AB_Split, $WA_fieldValuesStr);
$WA_connectionDB = $database_connmpmga1;
@session_start();
$insertParamsObj = WA_AB_generateInsertParams($WA_fieldNames, $WA_columns, $WA_fieldValues, -1);
$WA_Sql = "INSERT INTO `" . $WA_table . "` (" . $insertParamsObj->WA_tableValues . ") VALUES (" . $insertParamsObj->WA_dbValues . ")";
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
if ($WA_redirectURL != "") {
$WA_redirectURL = str_replace("[Insert_ID]",$_SESSION[$WA_sessionName],$WA_redirectURL);
if (($_SERVER["REQUEST_METHOD"] == "POST")) {
//WA Universal Email object="mail"
@session_write_close();
set_time_limit(0);
$EmailRef = "waue_index_1";
$BurstSize = 200;
$BurstTime = 1;
$WaitTime = 1;
$GoToPage = "?success=true";
$RecipArray = array();
$StartBurst = time();
$LoopCount = 0;
$TotalEmails = 0;
$RecipIndex = 0;
// build up recipients array
$CurIndex = sizeof($RecipArray);
$RecipArray[$CurIndex] = array();
$RecipArray[$CurIndex ][] = "xxxxxxxxx@mpmga.org";
$RecipArray[$CurIndex ][] = "xxxxxxxx@cox.net";
$TotalEmails += sizeof($RecipArray[$CurIndex]);
$RealWait = ($WaitTime<0.25)?0.25:($WaitTime+0.1);
$TimeTracker = Array();
$TotalBursts = floor($TotalEmails/$BurstSize);
$AfterBursts = $TotalEmails % $BurstSize;
$TimeRemaining = ($TotalBursts * $BurstTime) + ($AfterBursts*$RealWait);
if ($TimeRemaining < ($TotalEmails*$RealWait) ) {
$TimeRemaining = $TotalEmails*$RealWait;
writeUEProgress($EmailRef,0,$TotalEmails,$TimeRemaining);
while ($RecipIndex < sizeof($RecipArray)) {
$EnteredValue = is_string($RecipArray[$RecipIndex][0]);
$CurIndex = 0;
while (($EnteredValue && $CurIndex < sizeof($RecipArray[$RecipIndex])) || (!$EnteredValue && $RecipArray[$RecipIndex][0])) {
$starttime = microtime_float();
if ($EnteredValue) {
$RecipientEmail = $RecipArray[$RecipIndex][$CurIndex];
} else {
$RecipientEmail = $RecipArray[$RecipIndex][0][$RecipArray[$RecipIndex][2]];
$EmailsRemaining = ($TotalEmails- $LoopCount);
$BurstsRemaining = ceil(($EmailsRemaining-$AfterBursts)/$BurstSize);
$IntoBurst = ($EmailsRemaining-$AfterBursts) % $BurstSize;
if ($AfterBursts<$EmailsRemaining) $IntoBurst = 0;
$TimeRemaining = ($BurstsRemaining * $BurstTime * 60) + ((($AfterBursts<$EmailsRemaining)?$AfterBursts:$EmailsRemaining)*$RealWait) - (($AfterBursts>$EmailsRemaining)?0:($IntoBurst*$RealWait));
if ($TimeRemaining < ($EmailsRemaining*$RealWait) ) {
$TimeRemaining = $EmailsRemaining*$RealWait;
$CurIndex ++;
$LoopCount ++;
writeUEProgress($EmailRef,$LoopCount,$TotalEmails,round($TimeRemaining));
wa_sleep($WaitTime);
include("webassist/email/waue_index_1.php");
$endtime = microtime_float();
$TimeTracker[] =$endtime - $starttime;
$RealWait = array_sum($TimeTracker)/sizeof($TimeTracker);
if ($LoopCount % $BurstSize == 0 && $CurIndex < sizeof($RecipArray[$RecipIndex])) {
$TimePassed = (time() - $StartBurst);
if ($TimePassed < ($BurstTime*60)) {
$WaitBurst = ($BurstTime*60) -$TimePassed;
wa_sleep($WaitBurst);
else {
$TimeRemaining = ($TotalEmails- $LoopCount)*$RealWait;
if (!$EnteredValue) {
$RecipArray[$RecipIndex][0] = mysql_fetch_assoc($RecipArray[$RecipIndex][1]);
$RecipIndex ++;
@session_start();
$_SESSION[$EmailRef."_Status"] = $GLOBALS[$EmailRef."_Status"];
$_SESSION[$EmailRef."_Index"] = $GLOBALS[$EmailRef."_Index"];
$_SESSION[$EmailRef."_From"] = $GLOBALS[$EmailRef."_From"];
$_SESSION[$EmailRef."_To"] = $GLOBALS[$EmailRef."_To"];
$_SESSION[$EmailRef."_Subject"] = $GLOBALS[$EmailRef."_Subject"];
$_SESSION[$EmailRef."_Body"] = $GLOBALS[$EmailRef."_Body"];
$_SESSION[$EmailRef."_Header"] = $GLOBALS[$EmailRef."_Header"];
$_SESSION[$EmailRef."_Log"] = $GLOBALS[$EmailRef."_Log"];
if (function_exists("rel2abs")) $GoToPage = $GoToPage?rel2abs($GoToPage,dirname(__FILE__)):"";
if ($GoToPage!="") {
header("Location: ".$GoToPage);
JBWebWorks
It's working now. I removed all of the email code and the include pages and then did the Create Email Message again.
Not sure what i did the first time.
Another problem - I set the email to send to two addresses but only sends to the first listed? // build up recipients array
Don't know if this has anything to do with it, but I have an array in one text field on the form so this code i added to the page which also added it to the index_WAUE_HTML_WA_Universal_Email_1.php
the code added is
The added code would not cause problems.
If it sends to one, it should send to both. I'd check spam settings and spam folders to be sure that it isn't sending and you just aren't seeing it received properly.
JBWebWorks
Thanks Ray.
You are right; my mail server was not set up properly and a reverse DNS check failed so Cox had set my CPanel email server as a problem and did not allow mail to come through to my cox email address from my cPanel mail server.
I have now corrected the issue with CPanel.
Thanks for your help.
