Images are not uploading
Thread began 2/02/2015 12:34 pm by Paolo R | Last modified 2/02/2015 1:14 pm by Jason Byrnes | 397 views | 1 replies |
Paolo R
Hi Guys,
I am doing a simple upload images as part of a form, I've done it in a load of other places in the site but it won't work for some reason on this form.
I've done exactly the same process (that I am aware of) but no joy.
The form is submitting, and the database is being updated but the images are not uploading and it's leaving the database field blank.
Any idea why?
Attaching the file.
Paolo
homepage_feature.php
2 issues:
1) The form encoding type needs to be set to multipart/form-data
in the DW tag selectcor, elect the form tag, then in the properties inspector, set the encoding type.
2) in the update behavior, you have bond the image fields to the file form elements.
on the bindings panel, there is a bindings group for the upload behavior. in the bindings group is a Server File Name binding you should use that binding instead of the file elements fro the form.
